Fixed Tube Sheet Exchangers; Leak & Hydrotest
Hi everyone;
My question is on the FIXED TUBE SHEET Exchangers (tube sheet is welded to the shell), particularly, identifying a leak and hydrotesting;
The normal way is to water test shell side and look for the leaky tube on the tube side of the exchanger. Then, plug it or replace it.
But when the Shell side design pressure is lower than Tube side design pressure, how a leak can be identified, fixed and hydrotested? the shell side test pressure will always be low, not enough to show any leak!
I do appreciate your insights,
RE: Fixed Tube Sheet Exchangers; Leak & Hydrotest
Pressurize the shell side with air or nitrogen.
Remove both channel covers.
Coat the entire tube sheet with foamy shaving cream (both tube sheets).
The leaking tube will blow out foam.
If the unit is in the field, wind and rain may reduce the methods effectiveness.
Also the method can be confusing if you have multiple leaks.
The issue is when the shell side design pressure is way lower than Tube side design pressure, say 5 bar vs. 30 bar.
I don't think pressurizing the Shell side would work!
I have used Ultrasonics and Helium Leak testing to locate leaks under similar conditions.
Pressure Testing
http:
Vacuum Testing
http://est
Prior to any hydrostatic testing we would do quick air bubble test to get the big ones.
We would then install the shell clamps and test the shell while watching the tubes. Add the channel sections and use pressure decay to hydrotest the tubes while watching the shell side.
http://www.uesystems.com/prod_up_2000.asp
