Section View
Section View
Section View
If a spherical part is dimensioned in a section view, do these dimensions only apply at that particular section?  For example, if one were to dimension a hollow sphere (OD – 50mm+/-1mm, ID – 45mm+/-1mm) in a cross section, would one check these dimensions at many cross sections or only the cross section shown in the drawing.
RE: Section View
If you use an S before the diameter symbol it means a spherical diameter and would apply in all directions.
RE: Section View
Do you know if that is explicitly called out in a standard?
RE: Section View
Yes, dgallup is correct. One must have a "S" prior to the diameter symbol to represent a spherical diameter and it is in the standard.
Dave D.
www.qmsi.ca
RE: Section View
See section 5.15 of ASME Y14.5-1994 which discusses spherical features. An "S" preceding the diameter symbol is appropriate.
