Problem moving views
When I move a Drawing View, several of the dimensions does not follow (even though they are selected).  Therefore, I am unable to move a view without having to redo a whole bunch of editing.
How do I move a Drawing View without drowning myself in extra work?
hpon
hpon
RE: Problem moving views
You probably need to turn on parametric sketching.  This will be a little icon with a picture of a pencil drawing perpendicular lines, with a perp, equals, and parallel symbol on the top.  I don't know why this isnt enabled by default... but without it on none of your lines will stay attached to the drawing when moved.
Did you do a redraw after you moved the view?  I have seen symbols and notes that are view related not move when the view is initially moved but they will jump to the correct location after a redraw.
There are quite a few ways to associate dimensions, notes, etc to views.  I prefer snap lines for most drafting.
