Hole table and different depths?
Is it possible to show holes with same diameter but different depths in different rows in hole table? Example A Ø8 h12 x4 in one row and B Ø8 h10 x6 in other row. Right now the hole table counts all Ø8 holes (irrespective of depth) and puts the depth on the first selected hole. Depth column is taken with callout (%DP %HD). And is there a way to change annotation letters to my own marking?
RE: Hole table and different depths?
This will bring up a menu where you can change the prefix id of the holes, and re-order etc. The options button on here will bring uip more properties.
I don't know if you get these options with V20.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
