Changing Line Colors?
Is there a way to change plane and line colors in the part environment?
I found in tools-options-visualization where you can change the background color etc.
I've got a dark background and the lines and planes are all white. Then I have an inserted image that has a white background and the lines aren't changing to black when they're over the white background. Even when I change the main background to white the lines don't change to black.
RE: Changing Line Colors?
the line color (if set to none) is define by the color of the geometrycal set.
You can control Geometrical set color and line / point/surface color with and XML file that you have to define in your ENV file. Check the online doc for more information about standard.
The line color will not change according to background color.
Eric N.
