Relink drawing views.
I have a UG file which has both 3D part and drawing created in one file. I have to separate the drawing and  the model files. I created one more copy(Save As) and deleted dwg views from one file and 3D from another. Is there a way to link the drawing views in one file to the same 3D model in different file.
RE: Relink drawing views.
Oh I use UG NX 4.0.
Raju,
You can accomplish this using the File->Export->Part option.
Start with your original file, specify a new file, and then click the Drawing Selection option, choosing the drawing(s).
When prompted with "Do you want to add the current part as a component of the new part...", choose Yes.
You will now have a new file containing the drawing information (from your original file), with your original file as a component.
All you then have to do is delete the drawing from the original file.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
