3 phase ac motor with four slip rings?
I have come accross a 3 phase motor that has four slip rings on the rotor which i have never seen before. I originally thought that it was k, l, m and a neutral point ring but on closer inspection i found that there was a circuit between the two inner rings and and a seperate circuit between the two outer rings showing it isn't a neutral point... I was wondering if anyone had any information on how this rotor/ motor operates this way?
RE: 3 phase ac motor with four slip rings?
Muthu
www.edison.co.in
Rafiq Bulsara
http://www.srengineersct.com
"..the more, the merrier" Genghis Khan
Muthu
www.edison.co.in
