Test Equipment Needed
I am troubleshooting an intermittent generator problem. Information from customer is generator shuts down after running approx 6 hours. Only alarm is under voltage. Not sure if this is a secondary alarm coming in after an engine problem occurs.
I am looking for a multi channel recorder to monitor generator voltage, freq, governor actuator, pmg, etc.
I need approx 500ms update max ... quicker would be nice.
I would like it to connect to a computer and retain approx 30 minutes of information.
Does such a device exist?
BB
BB
RE: Test Equipment Needed
Muthu
www.edison.co.in
Just looking for a good recorder to give me a real time sequence of events.
BB
Developed to locate 'non-existing and mysterious' faults, intemittent faults or plain long term supervision with high time resolution. Extended zoom and reference curve overlay. Export data to Excel if needed.
We love it. We wanted it for thirty years and now we have it. We named it Arcus with a blink at ABB Argus.
Gunnar Englund
www.gke.org
http://w
Gunnar Englund
www.gke.org
Muthu
www.edison.co.in
http://www.electrorent.com/
Thanks again
BB
Gunnar Englund
www.gke.org
Depending on the place, do not discount mischief!
Aimlessly gathering slew of information could be just waste of time and money. How about having a couple of experienced people watch it, say after 5 hrs. Depending on how sophisticated the engine controller and display are, it can inform a lot.
Also there is much to the story that is not told. What do you have to do to bring the machine back online?
Rafiq Bulsara
http://www.srengineersct.com
I am not sure if it is breaker tripping on under voltage and generator continues running, or if generator is shutting off. As designed, 27 should trip breaker only.
Just wanted right test equipment to catch the event when it happens as it is such a long time between events.
BB
"..the more, the merrier" Genghis Khan
