Section View in Assembly
While in an assembly, is there a way to section some parts but not others? I saw a recent post asking this while in a drawing.... but what about in an assembly?
thanks.
thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Section View in Assembly
You shade the view and rotate it within the view's window.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
There is another easy way to do what you are asking.
When in the assembly, create a new sketch of the section that you want to remove.
When you do a 'Cut-Extrude' there is an option for cutting thru 'All components' or 'Selected Components'
Choose 'Selected Components' and make sure 'Auto-Select' is unchecked.
Now you just select all of the parts that you want sectioned with the sketch you just created. And everything you don't select will remain whole.
Dan
www.eltronresearch.com
Dan's Blog
