Grinding and Polishing Stainless Steel
When polishing 304 stainless with a 24 grit belt grinder, what could cause the stainless steel to flake off and produce divets and pits in the material? Any advice will be greatly appreciated.
RE: Grinding and Polishing Stainless Steel
Why are you using such a rough abrasive? I would expect tearing of the metal with 24g.
Plymouth Tube
I would start with a worn out out sanding belt.
This in turn could cause one to apply too much pressure on the belt.
The wrong abrasive on the belt where the grains are moving the metal instead of cutting it.
Not clearing the debris from the cutting area.
Not keeping the area cool.
What shape is the part in question?
Wet or Dry process?
What is the abrasive?
Look at the belts. The abrasive or the bonding may have been changed. If either is harder than it used to be it might not break down as quickly and cause more tearing.
Make sure that the pressure is light.
Related to the metal, it may have been over oxidized or over pickled in processing. You would get this pull-out until you are below this damaged layer of metal.
Plymouth Tube
