Thread Issue
Thread Issue
Thread Issue
We have the following issue:
We have a shaft Outside threads.  The Go Gage will not "GO".  However, the parts fit to the mating part AND the mating part checks "good" using Thread Plug Gage.
How can this happen?
RE: Thread Issue
Your GO gage is bad?
RE: Thread Issue
Go Gage is good, and we used 2 other go gages with the same result.
RE: Thread Issue
Use functional gages and compare to thread specification limits for both internal and external threads.  Sometimes simple gages cannot identify fit problems.
RE: Thread Issue
Just because 1 mating part fits does not mean that ALL mating parts will fit.  You GO gage will guarantee that all mating parts will fit.
RE: Thread Issue
As dgallup says, a go gage is checking one of the limits of permissable tolerance.  It is toleranced to be up at that limit.
Real mating parts on the other hand are quite likely somewhere in the middle of their permissable tolerance range so are more forgiving of other parts being outside of their permitted tolerance range.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Thread Issue
What is the difference between 1.00-32 UN-2B thread and a 1.00-32 NS-2B Thread?
