Initial Filling of Empty Space Downstream of Seawater Pumps
Would someone please tell me why we always first-fill empty spaces of desalination units (or once-through cooling systems) downstream of main seawater pumps? In my thought, it should relate to compressibility feature of air inside of empty space and that emptying that air with high speed make perhaps a lot of noises or damage something. Any explanation?
RE: Initial Filling of Empty Space Downstream of Seawater Pumps
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
The second reason is the same reason that we don't pressure test new piping with air. We pressure test with water (hydro-test). High pressure gas is much more dangerous than high pressure liquid because of the compressibility of the gas. If you had a leak or a pipe rupture, you don't want to have that line full of pressurized gas.
The third reason is water hammer. When the liquid hits the end of the line and the line becomes liquid packed, there can be a pressure wave as that liquid has to decelerate. That pressure wave can blow the top off a valve, crack the line, rip pipe supports loose, etc. You need to be careful of the fluid velocity at the point where the line becomes full.
A vacant line should be packed in a controlled manner that will not do harm to the line or the pump.
Johnny Pellin
The system is filled at 30-60 psi with the high pressure pump turned off and the product and waste valves open to slowly flush out any air, as it can damage the membranes if trapped. Even when the HP pumps are started, the valves between the pressure vessels and the pump are slowly opened to prevent large pressure differentials that can damage the membranes. Also, the pressures need to be carefully brought up to allow the permeate and concentrate valving to be set properly to design specs so the system doesn't recover too much water from the concentrate, as the salts left behind in the concentrate could possibly become concentrated enough to quickly scale out and damage the system or reduce output.
Everything you ever wanted to know about RO systems...
h
Johnny Pellin
While waterhammer can occur without blocked in segments, its effects would be corresponding smaller then when stopped by a rapidly closing valve and, if releasing air through a properly sized vent valve such that little air pressure is built up, it takes us back to avoiding runout conditions. But, it could also be that the vent valve is not sized for venting air at faster pump runout flowrates, in which case "2-phase waterhammer" might also be avoided. Air compressed by excess water momentum to such an extent that the water flow is temporarily reversed until air pressure reduces. Hey. Stranger things have happened. But the root cause would be high runout flowrates, so I'd revert to that reason.
You have never described the main pumps in your system. The problem with operation at the end of curve depends on the pump. Another example may help. Our largest water pump is a 10 stage barrel pump. All 10 impellers are in series, oriented in one direction. In order to counter the extremely high thrust that would result from these 10 impellers, there is a balance piston on the discharge end. The balance piston uses a pressure differential between suction pressure on one side and discharge pressure on the other side to counter the thrust of all 10 impellers. This particular pump normally runs with about 3600 psi discharge pressure. If we were to operate the pump with a wide open discharge line and no back pressure, there would be no discharge pressure against the high pressure side of the balance piston. Operating in this mode, the individual impellers would also be producing less thrust. But, there could still be many thousands of pounds of thrust produced by the impellers that the balance piston could not counter. Running this way for even 10 seconds could result in a thrust bearing failure.
Cavitation could be viewed as a long term reliability issue. But, water is the most destructive fluid for cavitation. Running in hard cavitation for 10 seconds at each start-up could result in cumulative damage to the first stage impeller. Depending on how often the process is started, this cumulative damage could be very significant. Also, while running in hard cavitation, the shaft deflection would be greater. I would expect an increase in bearing and mechanical seal failures by running in this mode.
Johnny Pellin
