Replace Concrete Panel with columns or any other suggestion
Hi Friends,
I have got an opportunity to analyse an existing industrial structure and replace the existing 150 mm thick concrete panels with steel column.
The reason is that the client need a bigger opening in concrete panels to move the machineries.
The scenario at the connection with concrete panels is like this.
UB530 x 32 KG Rafter is connected with concrete panels with 125 x 125 x12 EA Bracket
Also UB530 x 32 KG is connected with 250UB x 37 kg by 10 mm end plate stiffener 4- M20 bolts on 70 x 80 crs and access through panels is provided.
This means that the main member 530UB is only connected with the panel.
Now Eaves (180 x 75 PFC) are connected to Rafter with 130 x 10 Gusset plate with a weld. Also 2 M20 HS bolts is used to connect it from the top of the eaves.
Eaves are also connected with panels at 1.2 m c/c with 90 x 10 x 120 fms site weld which is connected to the eaves with shop weld. Inside the panel, 75 x 10 x 130 plate is already tied to the Y12 reinforcement in the wall and eaves are connected with this plate.
NOW THE QUESTION
Is it possible to expand the 3 m x 2.6 m opening to 5.5 m x 4.6 m
Also, is it possible to replace the panels by steel columns and a beams?
Is there any other suggestion for this issue.
RE: Replace Concrete Panel with columns or any other suggestion
I'm fairly slow, can i get a sketch?
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
Firstly, get your member sizes right.  A 530UB32 would be very skinny.  I think you mean 530UB82.
Next, you need to give us some more information about the building, e.g. length and width, bay size, height.  I take it the 250UB37 members are rafters for a cantilevered awning.
How extensive are the proposed modifications?  Just one bay or many?
Thanks for your replies. I am currently working out the drawings in AutoCAD. I will be able to upload the file tomorrow..
Mike,
It sound to me like you are asking us to design it for you!
It is quite a simple concept with a number of solutions if you think it through.
Just remember to check the overall stability of the building and the uplift with the panels taken out.
Thnaks for your assistance.. I just wanted to make sure if I am going in right direction or not.
Thanks again
