Grounded Y û Y MV transformers compare to ? û Y gounded Tr
Would any body tell me what are the benefits of both grounded Y – Y medium voltage transformers compare to generally used Δ – Y grounded transformer?
RE: Grounded Y û Y MV transformers compare to ? û Y gounded Tr
Grounded wye winding can have graded insulation and insulated for line-ground voltage which may make it less expensive.
David Castor
www.cvoes.com
Is depend on your application.
What is a 13.8kV grid.
You have check, if you can use ground wye, it will be second ground point in the sistem, not always possible.
Best Regards.
Slava
