Bus Bracing for 85kA
I need formula or chart to determine the proper bracing distances for 3-phase 1/4 x 6" copper bus. Each phase has 2 bars separated by 1/4". Please dont refer me to IEEE/ANSI or UL paragraphs (as done in answer to a similar question) as I don't have access to those :(
Thank you in advance.
RE: Bus Bracing for 85kA
If you have a real need for this kind of information, you have a real need to purchase the applicable standards.  If you don't have the standards, how do you even know what questions you need to be asking?
UL 891.
David Castor
www.cvoes.com
There's some reference data in the Copper for Busbars published by the Copper Development Association.
Using this data doesn't guarantee you will meet code requirements - and if it did then it would likely be a old British code because it is a old British text which has been patchily updated and transcribed for the web - nor does it guarantee that your equipment will survive an 85kA fault. With that huge caveat, it's an excellent reference. If you can get hold a hard copy it's even better, although it's been out of publication for a long time.
Thank you Scotty. Oh I forgot, the separation between the phases is 3.5"
