Subscript Superscript Macro VBA for Excel
thread770-138208: Excel Subscript/Superscript Macro
In line with the other piece of great code, I made a modification that alows you to use ^ for super, _ for sub, and optionally also use parenthesis () to mark start and end of sub or sup.
I hope latex former users, or matlab ones will love this !
Sub SuperscriptSubscriptSelection2()
' Taken from http://www.eng-tips.com/viewthread.cfm?qid=138208 as base source code,
' Then modified it to act over a selected range of cells. BAsically reqacts against ^ and _ and
' it is also possible to optionally use parenthesis () as well, with either ^ or _
    Dim NumSub
    Dim NumSup
    Dim SubL
    Dim SubR
    Dim SupL
    Dim SupR
    Dim CheckSub
    Dim CounterSub
    Dim CheckSup
    Dim CounterSup
    Dim Cell As Range
    CheckSub = True
    CounterSub = 0
    CheckSup = True
    CounterSup = 0
    ' Looping through all the cells in the active range
    For Each Cell In Selection
        Cell.Activate
        ' We count the number of super scripts and subscripts for each cell
        NumSub = Len(Cell) - Len(Application.WorksheetFunction.Substitute(Cell, "_", ""))
        NumSup = Len(Cell) - Len(Application.WorksheetFunction.Substitute(Cell, "^", ""))
        ' We arrange first the superscripts
        If Len(Cell) = 0 Then Exit Sub
        If IsError(Application.Find("^", Cell, 1)) = False Then
            Do
                Do While CounterSup <= 1000
                    SupStart = Application.Find("^", Cell, 1)
                    RestOfString = Mid(Cell, SupStart, 2)
                    If (IsError(Application.Find("(", RestOfString, 1)) = False) Then
                        RestOfString = Mid(Cell, SupStart, Len(Cell) - SupStart + 1)
                        If (IsError(Application.Find(")", RestOfString, 1)) = False) Then
                            SupL = SupStart - 1 + Application.Find("(", RestOfString, 1)
                            SupR = SupStart - 1 + Application.Find(")", RestOfString, 1)
                            Cell.Characters(SupL, SupR - SupL).Font.Superscript = True
                            Cell.Characters(SupR, 1).Delete
                            Cell.Characters(SupL, 1).Delete
                            Cell.Characters(SupStart, 1).Delete
                        End If
                    Else
                        SupL = SupStart
                        SupR = SupStart + 2
                        Cell.Characters(SupL, SupR - SupL - 1).Font.Superscript = True
                    End If
                    CounterSup = CounterSup + 1
                    If CounterSup >= NumSup Then
                        CheckSup = False
                        Exit Do
                    End If
                Loop
            Loop Until CheckSup = False
        End If
        ' We arrange second the subscripts
        If IsError(Application.Find("_", Cell, 1)) = False Then
            Do
                Do While CounterSub <= 1000
                    SubStart = Application.Find("_", Cell, 1)
                    RestOfString = Mid(Cell, SubStart, 2)
                        RestOfString = Mid(Cell, SubStart, Len(Cell) - SubStart + 1)
                            SubL = SubStart - 1 + Application.Find("(", RestOfString, 1)
                            SubR = SubStart - 1 + Application.Find(")", RestOfString, 1)
                            Cell.Characters(SubL, SubR - SubL).Font.Subscript = True
                            Cell.Characters(SubR, 1).Delete
                            Cell.Characters(SubL, 1).Delete
                            Cell.Characters(SubStart, 1).Delete
                        End If
                    Else
                        SubL = SubStart
                        SubR = SubStart + 2
                        Cell.Characters(SubL, SubR - SubL - 1).Font.Subscript = True
                    End If
                    CounterSub = CounterSub + 1
                    If CounterSub >= NumSub Then
                        CheckSub = False
                        Exit Do
                    End If
                Loop
            Loop Until CheckSub = False
        End If
    Next Cell
End Sub
