Louver for Solidworks 2007
Well, I am having trouble modifying the "Louvers", in the Design Library for Solidwork 2007 (Office Professional).
I know you just drag and drop on the sheet meet surface. But when I edit the sketch, and change dimension or rotate it, it works fine. Problem I get, is an error that reads:
"The part's thickness may not be compatible with the form tool. The thickness must me less then the minimum radius of curvature for the form tool"
RE: Louver for Solidworks 2007
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2ev, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
I don't use these features (Forming tools) so I am not familiar with them at all. And here at work, nobody has use them either.
Thank you
Thanks.
Cheers,
Anna Wood
With unasked for advice, regards, Diego
