Anyone having HX trouble in Compress build 6300?
I'm trying to build a fairly ordinary S&T exchanger in Compress, and it keeps crashing after the 'Channels' tab.  I was able to build it once, whiffing in some inaccurate mean metal temperatures, but when I went to change them according to the customer data, the tubesheets went from 3/4" thick to nearly 4"!!!
Woof.
Fitter, happier, more productive
RE: Anyone having HX trouble in Compress build 6300?
If anyone does have such problems, I suggest they contact Codeware directly, at support@codeware.com. It is best to attach your COMPRESS vessel design file to the email and to describe the problem you are having.
   "Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
  www.codeware.com
