PE Status for PVs
5
PE Status for PVs
PE Status for PVs
Hello all,
I am a Masters Student and an engineer and am curious as to the relevancy of getting my PE with my focus being on pressure vessels.  At the code shop I work at there is no PE that signs off on vessels, as this is not a requirement of the code.
So, is there an application of a PV PE that I am unaware of?
Would this be a pointless avenue to pursue or is there work that would require a PV PE?
I suspect the design of vessels at engineering firms may be a potential opportunity...
RE: PE Status for PVs
Where in the world are you located (this is a worldwide forum, and you could be from anywhere)?
This shop you work for - do they have their U-stamp, or maybe they have their U-2 stamp as well?  That information is relevant.
I'm in the central USA.
We have our U stamp and R stamp and some piping stamps to.
div 1 has no PE requirement
div 2 does have it.
go ahead and get it, always nice to have.
Plan on getting it.  Even if you don't routinely need it you may on occasion have customers that require it.  Also, it is not unknown for people to wind up working at places other than what they planned.
Thanks guys I this is what I will plan on doing.
*think
Jurisdictions may also require sign off by a P.E.
Wow, no PE sign off for Div1 in the USA?? Is this regardless of pressure and contents? So you don't have to get designs verified at all? Sounds dangerous to me.
In Ontario and I think all Canadian Provinces a PE must sign off on the design and calculations before a vessel can be fabricated.
"Wow, no PE sign off for Div1 in the USA?? Is this regardless of pressure and contents? So you don't have to get designs verified at all? Sounds dangerous to me."
What's dangerous about that?  I don't remember there being anything pertinent to Div. 1 on PE exam.
The contents of the PE exam is irrelevant but it proves they are competent engineers (usually). I would think it dangerous to not have a licensed engineer sign off on medium to high risk vessels.
Even though there is no engineer signing off on the PV, most (if not all) companies have an insurance company that provides (at a cost) an Authorized Inspector (AI), that signs off on every code PV.  This assures that the PV has been designed to Section VIII, which in turn assures that the PV is safe due to it being designed to the requirements of the accepted code.
we work with a code shop that has a person with a degree in botnay doing the designs.  Their inspector who is not a PE checks the information and the QC for the materials and assembly.  This is in the US.
In Canada, a PE is granted upon graduating from college (well after a review, but no testing of engineering skills and little if any waiting period).  You also get a silver band for your pinky finger.
Clipped
In part because of CEAB's close monitoring, candidates for the P.Eng. title who are graduates of Canadian B.Eng. programs are not tested in engineering principles after graduation. However, to receive the P.Eng. title, the provincial engineering associations have additional requirements beyond the B.Eng. degree. These typically involve additional work experience past graduation, letters of reference, and an examination (known as the Professional Practice Examination, PPE) covering ethics, intellectual property protection, and provincial law. This "law and ethics exam" is based on a national syllabus established by the Canadian Council of Professional Engineers, but it is administered by each province. For example, applicants in Quebec must be familiar with aspects of Napoleonic law, while applicants in English-speaking provinces must be familiar with elements of English common case law. Applicants must be fluent in the language of business used in their province or territory.
"we work with a code shop that has a person with a degree in botnay doing the designs.  Their inspector who is not a PE checks the information and the QC for the materials and assembly.  This is in the US."
This is what I mean. And 'PipingEquipment' does your inspector check the design aswell as manufacture? What if the vessel is built correctly but the design is undersized? Yeah it may not fail due to the large safety factors but add some corrosion or some cyclic loading and it may not be so safe.
Like dcasto said we are also Professional Engineers after graduating, however to sign off on designs we must be chartered. We also require 3rd party verification for most vessels, whereby the design verifier must have their CPEng and be able to sign off on the compliance certificate.
PE's are nice, but irrelevant to the issue at hand.  Hire competent personnel and you will do great.  The Botanist example is an unfair argument.  (You went from one extreme to the other.)  I know many shops that have non-degreed personnel and they do okay, but I require engineers with degrees at mine--they are very competent. (they don't give Engineering degrees away these days)
EngAddict our AI is different than some companies (I think, I've only worked at this one shop) in that he is associated with our insurance company.  Not only does he go over the calculations, he makes us prove the software we use (which I believe everyone has a responsibility to do anyways).  Then on top of that we have several audits, one with the insurance agency, and one with ASME.  These can get pretty intensive, and if we do bad enough we could be stripped of our stamp and/or our insurance.
Even so I see your point.  I'm sure that some companies pass vessels that should not be, and they slip through the layers designed to ensure all vessels pass, but I'm sure the same is true for anywhere else including the UK and Canada.  When I started working here I was the only engineer with a degree working on vessels, and I have corrected some mistakes, but they had been building vessels for some 20 years and none have failed.  Even so they saw a need for somebody who understands the principles of science that the other PV people simply didn't have the training for...so I guess my point is that every shop should have at least one trained engineer, even if they are not a PE.  Like DG72 said they don't just give out engineering degrees, engineers have done far more complex calculations than are presented in section viii, (calculus 1-3 and differential equations), heck I've only seen algebra in section viii!  The real advantage to having engineers in the mix at a shop is to have the theory behind some of these equations and rules, that and we are use to using the graphs and figures and we know how to do research better than the average joe.  So, engineers in my opinion will make the design process a bit easier, and a PE will likely make it a bit better but is unnecessary.
""What if the vessel is built correctly but the design is undersized? Yeah it may not fail due to the large safety factors but add some corrosion or some cyclic loading and it may not be so safe.""
Size of vessel is determined by process guys.
Corrosion is determined by process/corrosion guys
Cyclic conditions are determined by process/operating guys.
The poor old fab shop has to determine if the mechanical design is good for all conditions furnished to him as listed above as well as wind, seismic, vibration, and the pressure conditions per code.
Why should a PE have to sign off on a simple design to division 1.  It is a "given calculation" format that any High school graduate can do with a minimum of training as long as the "Manager of Engineering" of the fabrication shop reviews the calculations for accuracy.
The fabrication shop does not do the overall HAZOP and site review and do not know about conditions there and the overall design.  That is what the PE on the overall project is for.
@ vesselfab
By size I meant thickness, accounting for pressure, reinforcing, external loadings, etc. I doubt a school kid could accurately design a vessel. I am sure they could apply one or two formulas but to apply a code properly in combination for a variety of vessels takes a long time to master. Not all designs are simple, I wouldn't expect a PE to sign off on a 'simple' design.
Why do you assume I was talking about a fabrication shop? It could be a design office. People make mistakes and by enforcing 3rd party verification for high risk vessels (or at high risk locations) it reduces the risk and improves QA. To verify a design someone needs to take responsibility, even if the design is done by an engineer, there still should be a signatory who is licensed.
@DG72 & PipingEquipment
Don't get me wrong, I have no problem with engineers doing the work, I am one myself and am not licensed. Where I work only engineers do the design and verification of vessels, not usually a Chartered engineer. But for some vessels we require an internal verification, signed off by the CPEng; for others we require external verification, to be signed off by a CPEng at another company. It builds in redundancies. I verify designs that come from many other companies and there are always mistakes, it is human nature. Usually always minor changes but every so often you get something though could be dangerous if sent to fabrication without checking.
I have no doubt that someone without formal qualifications could very competently design vessels if they have been doing it for years but that is not really my point. It is more the quality assureance side of things.
Like PipingEquipment we get audits for ISO 9001, which allows us to verify designs. W/o this we also couldn't get insurance. Who takes responsibilty at a fabrication shop if the design fails? A PE can be taken to court but what are the legal responsibilites if there is no signatory?
I am not trying to criticize the way you do things more trying to understand how it works to ensure the same level of QA. Please don't take it the wrong way.
""Why do you assume I was talking about a fabrication shop? It could be a design office. People make mistakes and by enforcing 3rd party verification for high risk vessels (or at high risk locations) it reduces the risk and improves QA. To verify a design someone needs to take responsibility, even if the design is done by an engineer, there still should be a signatory who is licensed.""
Well, I suppose I said fab shop, because you were talking about fab shop AI.  And the fact that the fab shop is the one ultimately responsible for the mechanical design and fabrication of the vessel.  Yep, the fab shop is responsible to make sure the vessel is correctly designed and fabricated to be suitable for conditions stated in purchase order and specifications and ASME code (here in the states).
We do have a PE here that reviews every design calculation.
We have an EIT that is preparing to take his test for PE.
We also have another EIT that is a few years away from his PE stamp.
BUT back to the original question about a code vessel shop.
Div 1  no PE   Div 2 PE required.
I would suggest that the original poster get his PE stamp
In my experience, the AI checks that calculations were done, and that they generally appear to be adequate, but does not check the calculations themselves, or confirm that they are complete or correct.  The requirement really is to have someone doing the design that knows what they are doing.  Neither an engineering degree nor a a PE license is really necessary or sufficient, but there's not any other certification for vessel designers that I'm aware of.  But in response to the original poster, if you have an opportunity to get your PE and assuming it's not some huge burden for you to do so, then go ahead and get it.
Just from general engineering experience, it seems that you really need to understand what software is doing before you can reliably use it, it's not a substitute for understanding the problem at hand.
PipingEquipment:
While working for a major EPC firm, one of our younger PV Engineers (10 years out of University) obtained his PE and was appointed Chief PV Engineer shortly there after. Note he was the only P.E. in the PV Department. He subsequently became Engineering Manager.
Thanks for the information.  I'm already kind of the PV guy here at our company, but its nice to reaffirm the notion that getting my PE has the potential to boost me up the ladder faster, and it will probably help me get a better job if I were to leave my current job.
Oh! He subsequently became Engineering Manager. His job was out source to India, He is now unemployed.
L S THILL
LSThill,
Not so.
stanweld (Materials)
Right after he got  the P.E., he became Engineering Manager. His job was out source to India, He is now unemployed. (Ture)!!
 Yes! it did happen toward the end of December 2009, was out source to CHENNAI INDIA new office.
L S THILL
The vast majority of whom don't have a PE (industrial exemption) or (in my case) aren't in a country that requires registration.
The CEng is nice and often a prerequisite for promotion, but for us largely means you're still breathing, employed and haven't gone to jail in the four years after graduating.
Matt
ha ha guys. thanks for a funny read. A bit of my you know is bigger than you know.  oh, and I have a silver ring around my pinky! too funny.
Many opinions on such a topic.
Yes, Division 2 and 3 vessels. The reason Div 1 vessels do not require a PE review/sign-off is very simple. Section VIII committee and subgroups believe it is not necessary to have requirements in their Code book for PE review and sign-off based on a successful track record of safe pressure vessel experience.
Having the PE is a credential that would be a benefit for both vessel design, review of designs and forensic analysis.
I once got advice from an old timer who recommended against getting a PE if you are employed by a fab shop.  His arguement was that currently, if you are a designer at a fab shop, and you don't have a PE, then the shop takes ultimate responsibility for the design.  If you have your PE and you sign the documents using your PE, then your license in on the line and you are open to liability.  His arguement was "why take the responsibility on personally when, without a PE, the company takes the responsibility?"
Of course if you want to go into business for yourself, you would need it.
Tell your old timer sure the company will take responsibility, and most likely kick the person's a%% out the door that was the lead designer or representative that signed the Form U-1 for the poor design.
It has been my experience (in fact I have a minor fiasco sitting on my desk right now ) that a PE performing or reviewing the design calculations on ASME PV Sect VIII div 1 is not any more likely to perform it correctly.  The reason I believe this stems from the USUALLY normal fact that they just don't have enough depth of field or time in grade to subjectively look at the numbers at tell if what they are getting on paper or even via electrons is correct.  More than once I have had an API inspector or QC inspector field review a stamped package that has glaring errors.  Bottom line, it is the experience, not the letters before or after ones' name that determines ability.
Just my two bits.
