Diesel Exhaust Rain Trap (Definition)
We are working on a project for a portable air compressor bid where they are requesting a rain trap mounted inside the compressor enclosure for the diesel engine exhaust. Does anyone know where I can find a definition/description for this device or a source for an exhaust rain trap?
DERAILH
RE: Diesel Exhaust Rain Trap (Definition)
The ones I have seen comprise a regular flapper style rain cap mounted inside of a can with a drain.  Even on paper, it looks ugly.  In practice, it doesn't work all that well.
The flapper really needs to be out in the weather, where if/when it sticks, someone will notice and get it fixed.
Mike Halloran
Pembroke Pines, FL, USA
its just the way you run the exhaust pipe,
instead of going straight up, there is a T junction
exhaust goes up, drain trap goes down (with a drain on it)
