current phase imbalance
my client recently had a utility company phase loss.
After correction, I checked the phases for current.
A phase 1077A, B phase 1116A, C phase 354A
The transformer is a 750kVa 277/480v secondary.
RE: current phase imbalance
There's clearly a lot of single phase load either connected between A-B, or A-N and B-N, or a combination of both. You could re-distribute the loads to improve balance, but is it actually causing a problem to warrant the effort?
Gunnar Englund
www.gke.org
Are there 480V single phase loads?
I would also double check the amp readings and check the method, meter, CTs or anything else that is used for the measurements.
Rafiq Bulsara
http://www.srengineersct.com
Rafig is correct about the loading. Somehow I feel you need to do some more checking and would love to hear the rest of the story once you get more info.
Alan
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
A 738A B 723A C 696A.
I had the utility company set up ma five day monitor to see what is going on. I checked all larger motors and loads were normal.
Interesting! Any thoughts?????
You never mentioned how were they measured and if the second time measuring method was any different.
Rafiq Bulsara
Also, voltage was normal both times.
Rafiq Bulsara
