Naming drawing sheets in Inventor?
Ok, so I want to be able to name the sheet in the Inventor browser and have the title block pull that name into the title. Any suggestion???
RE: Naming drawing sheets in Inventor?
No way to "dynamically" pull this field into the drawing.
I found a VBA workaround posted YEARS ago for a previous version if INV by (or at) either sDotson or CBliss, but that was a lengthy, messy solution.
The only "Sheet" properties currently available are: Sheet #, Revision & Size
RATHER STUPID, HUH?
