Crotch Plate Design Guidelines
Hello there,
I am trying to find suitable information on the design of a T-Piece and a 30 degree crotch plate.
Where can I find suitable guidelines/instructions?
I have already checked the following, but need to check my results; Pipe Design for Engineers and ASME 31.3
Laurence
RE: Crotch Plate Design Guidelines
It is difficult to understand what it is you need.
What are you designing?  Is it a branch connection? I do not understand "crotch plate".  Can you expand on the information you are providing?
you can find the design steps at AWWA M11 for crotch plate and coller and wraper.
i will sent it to you if you do not have it,
regards,
if you wanna more advise just sent to the pressure and the diameter for your tee and i will help,
i design many tees, and big fitting
