Changing file and folder names NX5
I've made a model with Unigraphics NX5 on my pc but now I want to copy it to another pc. The problem is that the folder names are different and UG can't find the files anymore.
I also want to change the file names of all the parts and assemblies but I'm afraid that this will cause a lot of errors.
Is there a easy way or setting which will avoid all these errors?
Thank you!
Thank you!
RE: Changing file and folder names NX5
As for copying an assembly have you looked at the Clone function yet?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
If i were you i'd only change the name of the top level part,then 'save-as" each part from within the assemly.
Athough if it's not a big assembly you could re-name them all, but only if you can remember what they were changed to , then you could right click on them in the navigator and "replace component"
To change the load options, go, file-options-assembly load options,then from the "load" drop down, set to "from search folders", then browse using the "add folder to search" drop down.
