Routing ports disappear
Hi!
Working on a pipe installment in Mech. Routing. I use mastermodel approach and TC.
I have wave-linked ports in to the Assy from their parts and all seems to work, except that if I delete one of the wave-linked ports, it's parent port becomes completly invisible in all parts other than the port's parent part.
I can't seem to make it accessible even though I change ref. set, Show all, visible layers etc. The only thing that seems to work is to delete the parent port and re-qualify it. But that just seems wrong..
Does anybody have a smarter solution?
RE: Routing ports disappear
Bumping the thread.
The problem is still the same.....
/Martin
Found the solution so I'm answering myself.
There seems to be a difference in the Show commands.
Pressing ctrl+W and choosing "show all" seems to be less powerfull than ctrl+shift+U. At least when it comes to showing routing ports.
So ctrl+shift+U is the way to go....
/Martin
