Need associative centroid point
Does anyone have a way of creating an area centroid from a set of curves and then keep that point associative to those curves? Analysis->Advanced Mass Properties->Area using curves is not associative to the selected curves. Any creative solution would be helpful.
RE: Need associative centroid point
If the curves represent a 2D closed loop, extrude a very thin (0.001 mm) solid and then use...
Analysis -> Measure Bodies...
...and select the thin solid body and with the 'Associative' option toggled ON, hit OK and an associative centroid point will be created (see the attached NX 6.0 model as an example).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks John! Just tested for my application and works perfect.
