Yield Strength at Elevated Temperatures
ASME II Part D (we have 2004) has tables for tensile strength and modulus of elasticity for various alloys at elevated temperatures. I'm looking for tables for yield strengths. Is that covered anywhere in ASME? If not where can I find it?
RE: Yield Strength at Elevated Temperatures
MIL-HDBK-5 is another good reference (and free).
You may also look in the ASM Metals Handbook; they give you quite a bit of information on the effects of different heat treatments or processing on the mechanical properties of steels.
I found the table. Thanks. I don't use this code very often and when I do I always have a hard time finding what I'm looking for.
