Adding the Scale to the ISO Draft Template
Hi all,
How do I add the scale to the ISO draft template? I.e. how do I fill in that box?
Cheers,
Anthony
RE: Adding the Scale to the ISO Draft Template
Are you using the standard templates from SE?
If so then go up under view background sheet and then you can edit or add text.
Hi Woody,
Thanks. I'm almost there, but there's a problem. Although I am using the A3 sheet, when I choose view background, SE will only let me adit the A4 sheet. Any idea why?
Anthony
What background sheets have you got?
Sounds like you only have an A4.
You can create several background sheets - one for each size of drawing.
Then on the working sheet RMB on the sheet tab and select Properties. here you can set the sheet size and background to use for that sheet.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
