PUMPING FOAM
PUMPING FOAM
what is the best type of pump to use when I want
to pump a foam-type substance?? and why?
your help is appreciated.
RE: PUMPING FOAM
Bob
RE: PUMPING FOAM
flow rate (<15 GPM). can you discuss the/any potential ways
of handling this tricky material.
thks.
RE: PUMPING FOAM
RE: PUMPING FOAM
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
RE: PUMPING FOAM
http://www.pump-shop.co.uk/hygienic.htm
RE: PUMPING FOAM
