Attn: Handleman (macro help)
Handleman,
I am trying to use your MACRO on my home system with SW2008 WinXP PRO 64 but I get the following error. It works fine on my work system with SW2009 Win VISTA 64. See included pic.Let me know if you can help with this, thanks much.
Not sure if you were still following the other post.
RE: Attn: Handleman (macro help)
http://
http://fil
Unless I used new API functions. I can't remember.
Skiing today with my 4 1/2 year old daughter... worn out!
-handleman, CSWP (The new, easy test)
I will check it out and let you know tonight. Appreciate your help. Good luck on the slopes.
BB
Your suggestion fixed the issue I was having. Thanks very much.
BB
