Automating Pro/E Install
I am trying to automate the Pro/E install since I have to setup new user's machines quite frequently. I have tried the command line procedure in : h ttp://www. appdeploy. com/packag es/detail. asp?id=797.
Here is my single install line in my batch file:
R:\Installers\ProE_4\SETUP.EXE -nographics -uitrail myinstall2.txt
Here is myinstall2.txt:
! UI trail file version 1
! Application name `ps`
HIDE_SPLASH
~ Activate `ptcsetup` `NextBtn`
~ Activate `ptcsetup` `ScreenWelcome.AcceptBtn` \
1
~ Activate `ptcsetup` `ScreenWelcome.ProdButton.1`
~ Activate `ptcsetup` `ptcsetup`
~ Activate `ptcsetup` `ScreenLicList.PushButton1`
~ FocusIn `ps_lic_serv` `HostnameInput`
~ Input `ps_lic_serv` `HostnameInput` \
`g`
`go`
`gol`
`gold`
`goldm`
`goldmi`
`goldmin`
`goldmine`
~ Update `ps_lic_serv` `HostnameInput` \
`goldmine`
~ FocusOut `ps_lic_serv` `HostnameInput`
~ Activate `ps_lic_serv` `StdOK`
~ Activate `ptcsetup` `ScreenWindows.ScDesktop` \
1
~ Activate `ptcsetup` `ScreenWindows.ScStartMenu` \
1
~ FocusIn `ptcsetup` `ScreenWindows.StartInDir`
~ Input `ptcsetup` `ScreenWindows.StartInDir` \
`C:\\Documents and Settings\\m\\My Documents`
`C:\\Documents and Settings\\my\\My Documents`
`C:\\Documents and Settings\\myu\\My Documents`
`C:\\Documents and Settings\\myus\\My Documents`
`C:\\Documents and Settings\\myuse\\My Documents`
`C:\\Documents and Settings\\myuser\\My Documents`
~ FocusOut `ptcsetup` `ScreenWindows.StartInDir`
~ Activate `ptcsetup` `ScreenLpcfg.LCB.LpcfgCmdList` \
1
~ Activate `ptcsetup` `LpcfgCmdList.cmd_add`
~ FocusOut `ps_lic_sel` `CmdDesc1`
~ FocusIn `ps_lic_sel` `CmdName1`
~ Input `ps_lic_sel` `CmdName1` \
`proe`
`proe_`
`proe_m`
`proe_me`
`proe_mec`
`proe_mech`
`proe_mecha`
`proe_mechan`
`proe_mechani`
`proe_mechanis`
`proe_mechanism`
~ Update `ps_lic_sel` `CmdName1` \
`proe_mechanism`
~ FocusOut `ps_lic_sel` `CmdName1`
~ FocusIn `ps_lic_sel` `CmdDesc1`
~ Input `ps_lic_sel` `CmdDesc1` \
`P`
`Pr`
`Pro`
`Proe`
`Proe `
`Proe E`
`Proe `
`Proe`
`Proe/`
`Proe/E`
`Proe/E `
`Proe/E M`
`Proe/E Me`
`Proe/E Mec`
`Proe/E Mech`
`Proe/E Mecha`
`Proe/E Mechan`
`Proe/E Mechani`
`Proe/E Mechania`
`Proe/E Mechaniam`
`Proe/E Mechaniam `
`Proe/E Mechaniam D`
`Proe/E Mechaniam De`
`Proe/E Mechaniam Des`
`Proe/E Mechaniam Desi`
`Proe/E Mechaniam Desig`
`Proe/E Mechaniam Design`
~ Update `ps_lic_sel` `CmdDesc1` \
~ Select `ps_lic_sel` `List3` \
1 `127`
~ Activate `ps_lic_sel` `MoveToOut`
~ Activate `ps_lic_sel` `StdOK`
~ Select `ptcsetup` `LpcfgCmdList.CmdList` \
1 `1`
~ Activate `ptcsetup` `LpcfgCmdList.cmd_edit`
`Proe/E Mechanism Design`
INSTALL_THREAD
~ Activate `ptcsetup` `ExitBtn`
! Message Dialog: Question
! : Confirm exit from PTC.Setup
~ Activate `UI Message Dialog` `yes`
However, the command only runs for a few minutes then closes with no error message.
Thanks in advance for any advice or comments.
HIDE_SPLASH
1
`g`
`go`
`gol`
`gold`
`goldm`
`goldmi`
`goldmin`
`goldmine`
`goldmine`
1
1
1
`proe`
`proe_`
`proe_m`
`proe_me`
`proe_mec`
`proe_mech`
`proe_mecha`
`proe_mechan`
`proe_mechani`
`proe_mechanis`
`proe_mechanism`
`proe_mechanism`
`P`
`Pr`
`Pro`
`Proe`
`Proe `
`Proe E`
`Proe `
`Proe`
`Proe/`
`Proe/E`
`Proe/E `
`Proe/E M`
`Proe/E Me`
`Proe/E Mec`
`Proe/E Mech`
`Proe/E Mecha`
`Proe/E Mechan`
`Proe/E Mechani`
`Proe/E Mechania`
`Proe/E Mechaniam`
`Proe/E Mechaniam `
1 `127`
1 `1`
INSTALL_THREAD
RE: Automating Pro/E Install
Thanks for your response. Sorry it took me so long to get back to this. Are there any steps needed to associate proe files with the program in windows? For example running "proe /regserver" or something along those lines?
Thanks again!
The only extra step I do is add the path to the Pro/E bin directory in the PATH environment variable.
If you wanted to automate some of the associations such as just ".prt" you could use the following.
http://support.microsoft.com/kb/184082
BTW - I too was sad to hear that Pro/E was no longer supported on Linux when we started using it at Wildfire 3.
