"Project Engineer" Title
10
I am a licensed professional engineer (structural) that works for a Design Build firm.  Our company managers have a habit of calling new project managers "Project Engineers".  I have a problem with this, because the people they are titling as "Project Engineers" are new out of school with, at most, a 4 yr construction management degree (not engineering based). They then move up to being a "Project Manager" after gaining some experience.
My first job before I was licensed was at an A/E firm and we were not allowed to be called Engineers until we recieved our license.  Is anyone aware of legal issues with calling a project manager and Engineer without an engineering background?
We do a lot of work with the government, and I could see a big issue with a new PM giving advice on a project, and others taking their advice because they assume they have engineering credentials (such as recommendations on shoring, removing forms, and other means and methods issues that would usually be asked to an engineer).
I was told that "Project Engineer" is an industry accepted term for a green or new "Project Manager"  What are your thoughts?
RE: "Project Engineer" Title
In my old line of work a Project Engineer generally was the Engineer in charge of managing the Project.  AKA Project Manager.
In my current line of work any Engineer that works on a Project is a Project Engineer.
The title varies from industry to industry and probably from country to country.
Where I work, a "Project Engineer" is in charge of a project, from proposal, through delivery to billing.
- Steve
Up here...
A "Project Manager" does not need to be a licensed engineer, nor is a degree in engineering required.  A "Project Engineer" needs to at least have an engineering degree and must be registered either as an engineer in training or a professional engineer.
The instant you use "Engineer" in the job title, it's against the law to be anything other than an engineer.
SNORGY.
Hey Snorgy,
What state do you work in and do you know if there is a specific state that it is illegal to use "engineer" in your title?  In Wisconsin, it is illegal to use the term "professional engineer" without licensure.  Thanks,
-K
Oh dear, we're heading back into that groove again, where everyone assumes US laws apply universally.
- Steve
I am in the US, so I am concerned with US laws...  sorry, I did not clarify my location.  Let me know what country you are from if replying, so I know what is acceptable where....  thx
"The instant you use "Engineer" in the job title, it's against the law to be anything other than an engineer."
Unless you are in an exempt industry.
Most (but not all) states in the U.S. have a clause that allows for an industrial exemption.
In an exempt industry, it would be legal to use the term "Project Engineer" for someone without a PE license. However the OP was for a Design/Build firm and is talking about construction. I would think that would be a legal issue.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
Thankfully they don't.
In my opinion, the term "professional engineer" has a specific meaning as one who has a PE license.  I don't agree that one should have to have a PE to be called or titled as an engineer.  The reason being that the work that requires a PE or that is typically done by a "professional engineer" is only a small subset of the Engineering work of the world.  In the areas that don't, most companies go through a process of certification and testing to a defined set of standards by an NRTL which is usually intended to be equivalent to the services of the PE.  Should someone at least be required to hold an engineering degree from an accredited institution?  Perhaps, but does this requirement fit in all cases?
I have frequently had a conversation with a fellow engineer who is married to a lawyer (in the USA).  We agree that as a professional discipline, engineering went wrong in that it does not require some form of formal process of obtaining a license and continuing certification and ongoing learning.  If it had, as a profession, engineers would be in the same position as doctors and lawyers and would also be able to command the salaries that those professions get.  We also agree that there is a general skill set that all engineers should possess, but beyond that there is so much variety that having one certification and one test for all is not practical and instead it should be at least geared towards the discipline (electrical, mechanical, chemical, etc).
See me running screaming from the room.
Before I go let me provide my standard advice--Don't ask your bridge club for medical advice or a bunch of geek engineers for legal advice.  If you have a legal question, read the law in your jurisdiction and if you can't make sense of it hire a lawyer to explain it to you.
David
I know Wisconsin's law, but we have went from a local, general contractor and have grown much larger, now recognized as a federal contractor doing work all over the country in many different states.
I thought that maybe someone has run into this before, and at least could tell me what state they are in, or ran into the problem with so at least I could track down and read the laws in a handful of states, instead of 50.
The managers of the company are disagreeing with me on this, which is fine as long as they are not setting the company up for a legal issue.  I certainly am not going to pay the lawyer and as long as they disagree, they certainly won't until its a problem for them.
Thanks to anyone who can point me in the right direction.
Running, scremaing, yeah!
I wonder how the real big engineering communities will self-regulate.
- Steve
Same thing about every 2 days here.....
peace
Fe
My apologies...
By "up here", I meant "in Canada".
We don't have (based on my understanding) industry exemptions like the U.S..  It's pretty black and white: you cannot use "Engineer" in your job title unless you actually have a degree in engineering and are registered in good standing as an "engineer" in the applicable jurisdiction.
I erroneously thought that the same would apply in the U.S. - that there would be an equivalent exclusive right to title protected by similar laws.
What Noway2 alludes to in his closing paragraph may be true in the U.S., but in Canada, there actually *is* "...a formal process of obtaining a license and continuing certification and ongoing learning...".  I believe that is largely why the right to title can be protected by law.
SNORGY.
OK, it is like watching the same train wreck over and over, but there is a twist here that I have recent knowledge of.
With regard to Federal projects in the U.S., stand by for a major change.  Federal regulations (especially EPA) are starting to require P.E. signature and stamp on many different reports, forms, etc.  The EPA is silent on whether you need a stamp from a local state or if will any stamp do.  We are starting to see big firms stamp things like the EPA Spill Prevention and Countermeasures Control (SPCC) form with out-of-state stamps.  In New Mexico, the Board has stated the opinion informally that this is not legal, but there has not been an enforcement proceeding yet.  When the first enforcement action is requested, it will certainly be followed by a "cease and desist" letter to the companies involved.  I expect this to evolve into a major "States Rights" issue that will force a change in the federal regulations.  The board in my state has been very clear that if you stamp something which has any chance of impacting public health and safety within the state then the stamp has to say "New Mexico" on it.
David
Good go for it. (the argument)
My last attempt at "arguing" or rather explaining the LAW ended up with all deleted posts...
peace
Fe
...at the risk of continuing the pi$$ing contest...
knelli...The company I worked for some years back received a cease and desist letter from our state board for allowing EI's to use the term "Project Engineer" since they were not yet licensed.
While the states vary a bit on their protected titles, in general you can't use the term "engineer" in your title or offering unless you are in an exempt category, and even then you generally have to have a 4-year degree in engineering.
Construction/Design Build are by no means exempt categories.  My guess is your company is violating your state law.  Do they hold a certificate of authorization to practice engineering in Wisconsin?
"the LAW"" only applies locally.  No matter how big the font is or even if you use capitals.  USA is a teeny weeny part of the World.
- Steve
It must depend on which industry, or maybe it's a local/company thing.  In my company in the chemical industry, the "Project Engineer" coordinates/manages the detailed engineering design team to produce construction packages.  The "Project Manager" manages the overall project including process design, detailed engineering, procurement of equipment, construction, commissioning, and start-up.  They are two separate functions.
Good luck,
Latexman
Thank you Ron, That was the type of info I was looking for.  Would you mind sharing which state sent the letter so I can look at their laws?
Ironically, our company is big on getting "the company" certified in every state to practice engineering and be a licensed contractor in every state in which we work, even on federal projects.  We won't provide structural engineering on projects where our engineers are not licensed per the state's requirements even on federal projects where the contract specifically states that we are not required to be licensed in that state (I hope this doesn't start a new battle - I don't agree that the designers should be exempt on federal land).
Thanks again
David has a very good point. Dealing with the federal government is sticky.
They like the Professional Engineer stamp on documents, however, the federal government cannot recognize state laws (federal preemption). Their legal requirement is that a stamp from any professional engineer, regardless of the state that issued the license, is ok for federal work.
However, the EPA and others will be quick to point out that practicing engineering (whether for the federal government or not) needs a license from the state in which the project is taking place, and the state board will handle that issue.
But the federal government won't meddle with state laws, so I don't think they will deny the stamp from an out of state engineer.
Cedar Bluff Engineering
http://cedarbluffengineering.webs.com
3
This is very state specific in the US.
In Texas, it is perfectly OK for me to call myself a "Project Engineer" IF my firm is registered in the state AND I work under the supervision of a Licensed Professional Engineer (obviously, I am not licensed yet).
Apparently in other states they will send you a cease and desist letter, according to the above posts.
knelli...I am in Florida.  The letter was issued to my former employer, a large, international engineering firm with offices in Florida since the 1950's.
I had forgotten about another one...same firm...we had an engineer who was licensed in another state but worked in Florida.  Florida did not recognize the other state's PE since at that time they did not require the FE exam (that state has since changed its law and requires the FE exam).  Anyway, this engineer signed a report with P.E. after his name.  It was co-signed by a properly licensed engineer in Florida, but the subject area was not in his specialty.  We got a letter telling the out-of-state P.E. to stop using the title and another one reprimanding the in-state P.E. for signing a report outside his specialty.  He was only following company policy for administrative review, but got zapped because he was the only one who signed the report who was properly licensed in the state.
Photoengineer,
I've been an engineer with the federal government for a number of years. Your take on PE requirements is different than what I have understood, even when working in a federal contracting office.
Maurice,
I'm not surprised it's different....I think it is a new thing that some government agencies are instituting. I know for sure that it is the policy of the EPA to accept a PE stamp from any state, but the IRS wants a stamp from an engineer licensed in the state where the building is. Perhaps the expectations are different in different branches of the government.
(It's wrong for an engineer not licensed in a state to stamp off a drawing for something in that state. I want to be clear that I don't disagree with that.)
We're definitely clear on that. I guess the heart of the matter is all federal agencies don't do things the same way, some are backwards, and some are plain fup duck.
A problem I've seen a lot of times is non-engineers editing guide spec's for engineering. If you don't know what you are doing, editing the qualifications portion of a guide spec is pointless.
A problem area I have repeatedly encountered is agency use of Service Contract Act as opposed to Brooks Act. Under the SCA you might get better wage rates and lower initial cost; if for saving energy, such as re-commissioning, an SCA might suggest cutting back or out outside air (I've seen this happen in unfortunate places). The gubmint may pay more upfront for Brooks Act, but I have greater trust that a PE would not be doing nutty things. VFD application to everything that moves is more likely to happen (in my experience) when the PE is not involved. I have greater control/authority on energy funds, so a PE stamp by the State is required. I still have to convince the Contracting Officer (I've only worked with one Contracting Officer that was an engineer; one large federal agency I worked for had a policy disallowing engineers from working in Contracting-weird).
EPA has an in-state PE requirement for EnergyStar submittal.
mauricestoker,
Your last sentance is interesting.  Why in the world would they have an in-state requirement for one program and be silent on another program?  No, wait, it is the government.
David
Back to the OP (and I promise I will make this relevant), knelli was asking if Project Engineer is an industry accepted term for a green or new Project Manager.  I can only give you the perspective from MY industry, which is aviation in the United States.
Engineering in US aviation is an exempted industry as far as using the word "engineer" in a title.  The FAA ACO (Aircraft Certification Office) engineer and/or the FAA/DER (Designated Engineering Representative) stands in the place of a licensed professional engineer and all of us who perform engineering tasks must have what we design blessed by these individuals.
For example, I am not a licensed professional engineer.  However my job title is Project Engineer.  And contrary to your industry, in our usage it means I am expected to be an experienced engineer who leads of team of engineers (six in my personal situation) regarding technical and engineering decisions.  I do not have any managerial, supervisory or administrative authority.  I exist to insure that everything my team creates will meet the standards of the FAA ACO engineer and/or the FAA DER BEFORE they look at it, under the theory that the sooner we find issues and resolve them the more likely our final product will be blessed in the desired time frame.
So at least in my industry the term Project Engineer does not mean what it means in your industry.  I thought you might want to know of this exception, but it really does not affect you because your industry is a completely different ball game from the legal and oversight perspective.
I hope you found this interesting even if not useful.  :)
Seconding debondine's post. . .Our job title structure is very similar.
At a former employer in the Power EPC industry, Project Engineer was used as a title for the top-ranking technical engineer on a project. We are not exempt, so this person was always a PE and the one to stamp the drawings for his discipline.
For example, on a typical power plant project, the mechanical staffing would look something like this:
Project Manager (mostly dealing with managerial issues relating to the owner and construction partner, and overseeing the whole project)
Engineering Manager (managerial issues related to engineering and procurement)
Project Mechanical Engineer* (licensed PE, reviews all mechanical work)
Mechanical Engineers** (x 5-10 engineeers, levels I-IV, may also be licensed.)
*my current company calls this Lead Mechanical Engineer
**we can use the term "engineer" for any degreed engineer in my state, only "professional engineer" or "licensed engineer" is restricted.
HOWEVER, similar to the situation you are seeing, on the construction-partner side of the business, "ENGINEER" is used for the construction management professionals, regardless of whether their  BS degree is in CM or engineering.
A good practice I've seen with several agencies, especially for Brooks Act IDT's, is to spell out exact qualifications for positions. It's very hard to protect against "bait and switch" otherwise. All contracts I have seen generally use a requirement of graduatioon from ABET accredited school to use the term engineer, plus additional experience/education for specific positions (to include PE requirements).
I would strongly recommend against listing any intern or apprentice as an engineer on a federal contract, that will run afoul of FAR Part 31 and the Cost Accounting Standards.
If the gubmint does not spell out requirements, such as having PE, Structural for excavation shoring, and when it is required, then that agency needs to start editing its specifications. Worrisome part is it might not be an engineer (depending on which agency is involved) editing the qualifications. OSHA can and has fined the gubmint.
I have not yet met a gubmint engineer that did not have at least an ABET accredited degree. I've met a lot of project and program managers that have a degree in history.
Can someone point me to the EPA requirement for Energy Star requests?  We recently got a product ES approved and there aren't any licensed engineering involved.  Also where in the state laws is all this "proper name calling" mentioned.
drawn to design, designed to draw
The requirement is in the application package. The PE must be licensed in the State in which the facility resides.
It's listed under the Download, Sign, and Mail Letter of Agreement and SEP to EPA.
An exception is given for federal facilities and employees; if a federal employee, out-of-state is acceptable as long as it is allowed by the State of licensing.
Professional Engineering Licensing is Dead. Industry has successfully killed it. Sorry to say - but it is true, and Engineering Boards are powerless to stop it.
I worked hard for my P.E. but it is now irrelevant, a meaningless credential. I see absolutely clueless clowns calling themselves "engineers" designing foundations, superstructures, connections who would not know how to analyze a free-body-diagram.
Across the board, mechanical, civil, structural, chemical - you name it. Design is being off-shored, accountability is nil.
America is now officialy a third-world country. I doubt I will even bother renewing my license. throwing good money after bad.
RoyTyrell,
Your post raises some valid points.  Namely that cost is having a tendency to drive towards the lowest bidder / lowest common denominator.  In my experience, Off shoring definitely makes design accountability a lot harder.  It places some serious responsibility on the few remaining on shored engineers that must qualify the work.
Personally, I would really like to see the bar raised for ALL engineering disciplines.  I think that some form of standardized qualification is required.  I think that the lack thereof will ultimately demand a serious price tag.  Unfortunately, the current PE system falls far, short of this goal.  The answer, of course, is to expand the system, but as I said in my previous post, there needs to be some sort of discipline differentiation.
Take for example, software.  Most "embedded" software is NOT developed by computer science people.  Most of it is developed by electrical engineers. One driving reason for this is that the EE has a much easier time understanding the hardware that they are trying to control. How many critical systems today depend on software?  Cars, planes, nuclear power plants, fire and other life safety equipment, etc, basically most of the nations infrastructure are all only as safe and reliable as the software running them.  Does developing software currently require any sort of certification?  Hell, no.  Should it.  Hell yes.
Noway2,
If cars, airplanes, and nuclear power plants are designed by unlicensed engineers, why should the software that runs them be any different?
I don't think that any of it should be, but I also think that only real engineering certification system that exists (the PE) falls miles short of the necessary target.  Fortunately, the day is coming where certification standards will be required.  Unfortunately, that day won't come until there is a grave tragedy that brings awareness to the requirement.  If I am not mistaken, at least one plane crash was attributed to bad software.  In the industry I currently work, bad software has caused Fox News to go off line and brought down the NASDAQ due to loss of power.  A more comprehensive and up to date certification system for engineering is desperately needed.
Roy, speak for your own industry, not for mine.  There is almost nothing meaningful that can be said about "engineering" as a general concept, rather than about specific disciplines.
And, frv, not everyone in TX agrees with your interpretation of TX law.  I was an Engineering Assistant, not an Engineer, until I got my license, for legal reasons, even though I was working for a hierarchy of PEs.
Hg
Eng-Tips policies:  FAQ731-376: Eng-Tips.com Forum Policies
HgTX-
I was actually of the opinion that I could not use the term "engineer"..  They actually beat that into you in school..
The reason I posted what I did was that a colleague pointed out the provision in the Texas Board rules and I read it myself..  it was pretty unambiguous.
Just to follow up..
http://www.tbpe.state.tx.us/downloads/law_rules092009.pdf
The above link takes you to the Texas Engineering Practice Act.
On p. 22, under "Graduate Engineers" (Section 1001.406), part (b), it states that I may use the term "Engineer". In my previous post I stated that I could use the term "Project Engineer". If I had to guess, I'd say that if you are allowed to use the term "Engineer", it would be perfectly OK to use the term "Project Engineer", but I'd be curious if others would interpret this differently.
"If cars, airplanes, and nuclear power plants are designed by unlicensed engineers, why should the software that runs them be any different? "
I can't speak for automotive, but airplanes, power plants, and military hardaware, and the software that controls this stuff are highly regulated.  I am going out on a limb here, but my opinion is that the whole idea of having a licensed engineer is to ensure the safety of the general public.  So in this vein, I see no need for licensure in the presence of a regualting body.  It is indirectly through this regulating body that the general public is protected, not directly through the licensure of an individual engineer. Products (software or hardware) for these industries goes through extensive reviews and approvals and ultimately must pass rigorous qualification tests before this stuff is deployed in the field.
That section specifically states that a graduate engineer may use the term "engineer," by itself, ONLY if they are working under the direct supervision of a licensed professional engineer.
Note, specifically, the definitions at the start of the document:
"(2) "Engineer" means a person licensed to engage in the practice of engineering in this state."
And,
"A person who is an employee or subordinate of an engineer is exempt from the licensing requirements of this chapter if the person's practice does not include responsible charge of design or supervision."
TTFN
I read that part of the document but, as I pointed out, and you saw, there is an exception to it for graduate engineers.
Short of calling the board myself and asking them, I'd venture to say what they really care about is not using the term "Professional" or "Licensed" in any way unless you are actually licensed.
I know the general public won't know the difference but pretty much anybody engaged in engineering would know that if your title is "Project Engineer", you're probably not licensed..  at least in the structural world, that's the case..
In any case, that's why I brought this up, to see whether other people would think that "Project Engineer" is, in the spirit of the law, what the board intended or whether they think it is a violation of the spirit of the law...
My opinion is that we're getting caught up in semantics and kind of missing the big picture.
Well, agree to disagree.
I think the definition they included speaks for itself.  They allow the exception for "graduate engineer" and an "engineer" working directly under the supervision of a PE.  I don't see that they allow any other exceptions, except for exempted industries and companies.
TTFN
Wonders of the modern world..
I called the compliance division of the state board and asked them directly. They said I can use the term engineer AND any variation thereof, provided I do not represent myself as, or call myself a Professional or Licensed engineer.
Forest for the trees, gentlemen.
frv...you seriously misread the law.  Section 1001.406 states that you may use the term "Graduate Engineer" if you are a graduate of an ABET accredited engineering program.  The preceeding paragraphs (1001.405) specifically prohibit the use of the term "engineer","professional engineer", etc. unless you are a licensed professional engineer.  This comes under the "Business Entity" section which includes by its definition, sole proprietors or individual engineers.
The term "Graduate Engineer" is definitive.  It means that you have graduated with a degree in engineering, but distinguishable from "Licensed Professional Engineer".
Ron..
did you just skip over part (b) of 1001.406?
did you just ignore my previous post?
I CALLED the board. The compliance division, no less. I specifically asked them if I was misinterpreting the Law and was told I was not. And yes- I specifically asked about the term "Project Engineer".
I doubt that any public agency is much better than 60%-80% accuracy rate when it comes to answering questions, particularly verbal ones over the phone; q.v. IRS hotlines.
It may very well be that they'll only enforce blatant violations, i.e., posing as PEs, as opposed to calling yourself "Structural Engineer," which technically violates the code.
If you ask them to put it in writing, you'll probably either get a different answer or no answer or a regurgitation of the PE act.
TTFN
Maybe, in which case they should say that over the phone. If I phone the relevant authority up and they give me an answer, I think that a reasonable person would say that I have checked and received advice.
Cheers
Greg Locock
I rarely exceed 1.79 x 10^12 furlongs per fortnight
Only if you note the date, time, and name of the person you spoke to.  Otherwise, it won't stand up.
Good Lord!!!
Are you serious??
Is it so important for you to "win" this idiotic pissing contest that you actually have to question the qualifications of the COMPLIANCE DIVISION of the state board?
This is ALL they do!!!  They receive complaints and investigate whether the complaints are violations of the code..  who would be better suited to inform me whether a provision is in violation of the code?
I have nothing whatsoever to gain in this discussion, since I work in an exempt industry; those that take the verbal advice of an unseen, unknown person without documentation take a non-zero risk.
I simply point out that the written law is at odds with the information you received, and at odds with the PE law in my own state.  You can accept this person's advice and take your chances or not; it makes no difference to me.
TTFN
IRstuff-
I have nothing to gain from this either..  I don't use ANY title. That is my choice.
If you would have bothered to go back and read my original post, I stated that the use of the term is something that varies greatly by state- that is where this whole thing started. For example, my boss started practicing in Maryland and he told me that back when he was there, pretty much anyone could call him or herself an engineer, regardless of education or licensure.
In TEXAS and only in Texas is what I posted valid.
And unless you studied Law before going into engineering, I don't think you are qualified to state categorically that "the written law is at odds with the information you received". I am quite capable of reading the law myself; I did and I came away with a different interpretation than you. That's fine; intelligent people are free to discuss what they will and have differing opinions. But when I ask the people who are responsible for determining whether something is a violation or not, that should pretty much settle it.
frv
My point was simply that, as a respected 'professional' (dare I use that word here?), if you are basing any action on the verbal answers given over the phone, it would behoove you to note the date, time, and the name of the person who gave you the advice, lest it blow up in your face.  You may have been speaking to the daughter of the brother-in-law of the guy who sits in the cubicle of the guy next to the one where the phone rang when you called.  Without verifying your source, you have no more idea who you got the answer from than from a semi-anonymous poster on an internet forum.  And without anything noted down, you will never be able to defend yourself if push comes to shove.
I called and spoke to a guy.
Who did you talk to?
The guy who answered the phone.
What was his name?
I have no idea.
In this particular case, there is no particular importance to that issue, this is basically just idle conversation.  However, if you ever used the same strategy on anything important, and it came to a court case, you'd have a bit of an issue maintaining credibility.
Apparently, none of us studied law, otherwise we would know that a verbal communication from persons unknown is not a legal decision.
Just as we have a difference of opinion, so do people in the legal profession; that's how they make their living, by arguing points not that different from this one.
When I read:
and someone tells me that I don't need a license to print and use the term "engineer", that's a huge discrepancy, and I have to fall back on what's in the PE act.
TTFN
A lawyers advice is not law either. There are lawyers on both sides of every case. Judges get overturned but "professional courtesy" makes that less likely. The only ones who do not lose are the lawyers and judges that get paid either way. For the rest of us it is a crap-shoot that is very strongly influenced by who has the most money. So the answer is there is no right answer.
Seems pretty clear that frv is correct.  "A graduate engineer, working under the direct supervision of a licensed professional engineer may use the term engineer."
Crystal clear...in Texas that is.
The point of contention was not about "graduate engineer" per se, it was about what "project engineer" might mean under the code.
TTFN
Well, "engineer"  in section 1001.002, is defined as "a person licensed to engage in the practice of engineering in this state".  And since section 1001.406 specifically allows an unlicensed person to use this term, I would say it's pretty clear.  The term 'project' appears to be meaningless as far as the state of Texas is concerned.
IceNine..you just pointed out an apparent inconsistency in the statute; however, it is likely that the intent in 1001.406 was to not allow the broad use of the term "Engineer" by non-licensed persons.  "Project Engineer" in many states is a protected term, implying licensure.
As IRstuff noted, an oral interpretation by a staff member carries no credence or weight.  A written interpretation by vote of the board or by board counsel is the appropriate method to resolve ambiguity and misinterpretaion of the code.
1001.301. License Required
(f) Notwithstanding the other provisions of this chapter, a regular employee of a business entity who is engaged in engineering activities but is exempt from the licensing requirements of this chapter under Sections 1001.057 or 1001.058 is not prohibited from using the term "engineer" on a business card, cover letter, or other form of correspondence that is made available to the public if the person does not:
    (1) offer to the public to perform engineering services; or
    (2) use the title in any context outside the scope of the exemption in a manner that represents an ability or willingness to perform engineering services or make an engineering judgment requiring a licensed professional engineer.
(g) Subsection (f) does not authorize a person to use a term listed in Subsections (b)(2)-(6) or a variation or abbreviation of one of those terms
In other words, if you work for a licensed firm, but are not licensed yourself,  you can use the term 'engineer' in your title, as long as you don't perform engineering work, or use the term Registered/Professional/Licensed Engineer.
That's fairly clear, isn't it?
TenPenny...while it's clear on its face, if you put a title on your business card and give the business card out for contact in the public sector, you could be violating this part of the statute unless you are licensed. Giving your business card out is an implicit offer of services.
Why would you work for an engineering firm, hold the title of engineer, and not do engineering work (unless you are strictly in management....and then why would you use the title "Engineer" other than you usurp its importance in the engineering world to give yourself credibility).
I have never understood the whole name calling issue.  If someone wants to call themselves an engineer let them.  It doesn't bother me at all.
Every single licensed engineer I have every met puts P.E. behind their name on their business card, email signature, etc. that is how I know that they are licensed.
If that suffix is not there I assume that they are not licensed, and so far that has always been the case.
But I guess I am in the minority and the issue will rage on for years to come.
ash060-
That is exactly what I was getting at. Perhaps our colleagues in other disciplines are getting their panties all up in a bunch because it not that common for them to be licensed. In our discipline, it is almost a given that you will at some point become licensed. Consequently, we can easily identify who is and who is not licensed. The term "Project" is absolutely meaningless in this discussion. Again, I think people are missing the forest for the trees on this one.
I graduated from college may 08 with a civil degree and immediately took the title "project engineer" even though i am technically an E.I.T. engineer in training.
Unfortunately this year i've gone within the same company to field surveyor to being asked to pose as receptionist and answer phones for a week while she's on vacation before beginning my undefined furlough (sp?) time.  Sanitation engineer may be in my future haha.
LOL...I guess going back to school may or may not fix that problem. My head would explode if somebody asked me to answer a phone.
peace
Fe
I am a Johnny come lately and I have only read the last few posts not the 60 odd before,
ash060
How do you feel about Lawyer (Juris Doctor) calling themselves a doctor ***** (specialling in law), and using this to gain clients when dealing with medical law suits.
Clearly the issue isn't the use of the name; names mean nothing it is the implied meaning behind the name.  We spend lots of time trying to educated friends/strangers as to what we do as engineers and what we are. We have codes of ethics that are part of the education process and are reaffirmed when seeking a licence.  Confirmation of this is engineers being ranked high in most surveys as being trustworthy.
To have someone claim part of this good work, possibly eroding this good will by using the name is to me is fraud. I don't know what the rule are for each state regarding what and if you can use the word engineer, but in my opinion unless you have gained the right to share or erode this good will by gaining the required experience/ UNI degree ect, then you shouldn't get to share in any of the good will that comes from/with the name.
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
I think this all comes down to misrepresentation. It is conceivable that a project manager may only have a degree in business management and no knowledge of engineering science. If, on the project, a member of the team introduced himself as a "Project Engineer" when he had no engineering qualifications or experience he would be guilty of misrepresentation or simply impersonating an engineer. Similarly if I introduced myself as a law enforcement officer to a member of the public when my actual employment was as a retail store security guard I could be found guilty of impersonating a police officer as the member of the puplic would assume I was a police officer.
Everyone would like a job-title that makes them sound more important than they are. A great example I heard whilst working as a chef during university was Kitchen Hygeine Engineer or a pot-wash to you and me..
I think any company that actively uses the term 'engineer' to describe a person with no engineering experience is deliberately misleading people and as stated before, it could lead to avoidable accidents occuring..
