Creating a slit in a solid object
I have a quick question... how would I make a slit in a material? Like... if you have a cube and you wanted to make a slit through two faces of that cube, like to thread a piece of string through it, for example.
If you guys could tell me what function to use, I could look on help/search or even google. THanks a lot.
Sorry, I'm new to solidworks.
RE: Creating a slit in a solid object
Dan
www.eltronresearch.com
Dan's Blog
If you sketch a rectangle and do a regular cut extrude (requires closed profile) you have to dimension the thickness of the rectangle.
Good Thing to learn now:
Once a Feature is made as a Thin Feature there is no way to change the type from thin to solid without deleting the feature and recreating with a modified sketch.
Michael
