NX gap detection on parasolid model?
I have this question,
NX can detect the gaps and data error imports on a parasolid, IGES, STEP (neutral CAD format files)???
I mean detect where are the import errors on 3D model surfaces, and fix them with NX surface module.
Thanks.
RE: NX gap detection on parasolid model?
Yes - I've done this in NX the last ten years ;)
How can you detect surface gaps on NX?
which icon you use?
thanks.
Analysis->Examine Geometry
I see thanks.
And to 'fix' gaps and other model problems, go to...
File -> Export -> Heal Geometry...
Note that this will create a second part file which will contain the 'repaired' body(s), but any parametrics will have been removed, but since it's a copy, your original part file will be intact.  You will also get a summary of exactly what needed to be repaired and if it was successful.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks both uwam2ie and John,
NX has so nice shape design module.
I have used before Catia but NX is so nice and easy.
Thanks.
