Calibration of Turbine Flow meter
We have installed a turbine type flow meter for measuring the Nautral gas flow. Its range is 11840 cu.m/hr and the pipe size is 8 inches, make fluid control. I want to know the calibration procedure. Also i want to the equipments requried for the calibration. we had send this instrument for external calibration, that company say that they only calibrate by simulating the frequency. But we want the actual calibration i.e. bench calibration. where do i get the correct information
please reply to abdulraheem88@hotmail.com
thanks
thanks
RE: Calibration of Turbine Flow meter
you may be knowing that flow is directly proportional to square of differential pressure
you can use pitot tube or anubar to measure the flow this will definately give clear idea .as this measurement is cannot be done on twest bench but you can install this measurement near the flow meter to crosscheck the reading.
good day
smar2001
follow mass balance calculaton
good day
Good luck. Natural gas has a unique compressability factor.
