Interior Steel receiving fire spray
Do you spec structural steel receiving fire spray to be primed if it is in non-corrosive environment? . What is the standard practice?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Interior Steel receiving fire spray
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
The removal of loose mill scale and surface contaminants is generally required before application, so that the bond between the coating and the steel is not compromised, whether it is the direct applied SFRM or the primer for an intumescent coating.
So, for the cementitious SFRM it is a no no and for intumescent it is yes. Why?
If corrosion is a no problem then priming should not be required in either case and if it is bond problem, I think the SFRM doesn't provide corrosion protection. Do you prime steel not receiving fire protection in a non corrosive environment?
Intumescent is a paint so it's no suprise that a suitable primer will increase bond.
