Multiple Objects in Specification Tree
When working on a surface in a geometrical set and for instance, adjust the control points on this surface, a new adjusted surface and the original surface appear in the specification tree. Is there a setting in options that either hides the original surface completely so as it does not appear on the tree or does not make a new surface and keeps the original surface with the adjustment made to it. Am working in non-hybrid mode.
RE: Multiple Objects in Specification Tree
CEROGs CATIA Blog(German): htt p://www.ca d-gaenssle r.de/de/ce rogs-catia -blog.html
Whenever you access the FreeStyle Workbench, you should see a toolbar named "Tools Dashboard". The third button on this toolbar, called "Keep Original", is what sets this thing for you. See image below:
If the button is "pressed" (see image below), each modification will duplicate the surface that is modified. If the button is not "pressed", the same surface can be modified multiple times.
Hope that (still) helps...
Best regards,
Stely
I'm VERY surprised that didn't take care of it...
Haven't used R19 yet, it might behave differently... maybe another one of Dassault's "improvements"
Best regards,
Stely
