Dual Monitor Software OpenGL Option
I'm currently running two monitors, with one being a widescreen. The settings between the two are identical except for the resolution (1600 x 1200 vs 1920 x 1200). The widescreen is my secondary monitor where I have solidworks most of the time.
If I have solidworks on my primary monitor, I don't have to have the check box for "software OpenGL" checked in order to see my model. However, if I move solidworks to my secondary widescreen monitor, the viewing window freezes. I can activate sketch and modeling commands, but i can't see what I'm doing...whatever the last image was on the screen is what stays there. If I check the software OpenGL box, it runs on both monitors, but it is clunky and doesn't run near as well as it does on the primary monitor without that option checked.
I've browsed a few other threads and didn't find any conflict of interest in having two different sized monitors, am I missing a setup option or should I just expect to have the OpenGL option checked when working on my widescreen? Solidworks keeps warning me that it is on every couple days like there is something wrong, and I can't use every feature (not that I would consider the magnifying glass handy, but it is one example of something I can't use).
Windows XP x64
Xeon X5482 Processor
8 GB Ram
Nvidia QuadroFX 4800
Windows XP x64
8 GB Ram
RE: Dual Monitor Software OpenGL Option
-handleman, CSWP (The new, easy test)
Eric
Thanks Ron
h
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Has anyone had this problem and actually found a fix?
Dell T5500
WINDOWS XP PRO x32
4 GB RAM
NVIDIA Quadro FX1800
Dual 23" Samsung SyncMaster 2333 wide screens
1920 x 1080 Resolution
