steel eye and hook
steel eye and hook
steel eye and hook
Does anyone have an understanding of what the design values would be for a steel eye and hook. I am considering using this connection in a timber truss where the bottom chord is spit in two pieces with a steel rod and plates connecting the bottom chord.  At the center of the steel rod is the eye and hook connection.
The steel eye and hook I am considering is 1" diameter thick and is 6" in diameter.
Thanks for your help."
RE: steel eye and hook
Are going to use a lag eye bolt and screw it into the top chord?
I suspect that this idea won't get past the Code Enforcement Office.
I don't like it myself, all of the eggs are in one basket.
Michael.
Timing has a lot to do with the outcome of a rain dance.
I am not sure of the application or suitability. However, if you want to check Thread 507-238156, it may provide a link to information about such connectors, wire rope etc.
