Long Bore Orifice
Long Bore Orifice
I've been given the task of calculating the flow of a compressible fluid (nitrogen in this particular case) through a long bore orifice (it WILL potentially go sonic). I suppose the best way to think of it would be a hole drilled thru a fitting in the end of a rigid vessel. The hole is about 3/8" in diameter while the fitting is about 2 to 3 inches in diameter. The length thru the bore of the fitting (to the interior of the tank) is about 1.5 to 2 inches. I am not certain what equations to use for this application since it seems to be somewhere between an orifice and a flush inlet to a short tube. Anyone have any recommended formulas for calculating compressible mass flow rates in this situation? I am leaning towards a tube long tube with a contaction coefficient factored in for the vena contracta I assume will be there. I am also not certain that the contraction coefficient is constant since it seems to me that it might vary with flow rate. Thanks for any input!
RE: Long Bore Orifice
Is this the thickness of the metal the 3/8" hole goes through? If not, what is that metal thickness?
Good luck,
Latexman
Will Chevron Corp.
Bob
So, you were leaning the right way!
Good luck,
Latexman
Will Chevron Corp.
This vessel I have described is in another larger vessel. Both are initially under vacuum. We need to repressurize both vessels so that the vessel I am asking about is not crushed in the process. It is a very thin wall vessel and cannot take a large pressure differential outside to inside during hte backfill process.
