METHODS OF TESTING THE DRAINAGE SYSTEMS
Somebody know how I can test a drainage system in a multistory building? The problem here is that the first level is finished and I need to test the second level.
I really appreciate your help.
KMora
RE: METHODS OF TESTING THE DRAINAGE SYSTEMS
Insert an inflatable pipe stopper on a convenient wye fitting. If that won't work, cut the pipe for the testing.
Thank you so much. I was thinking the same that you explain me but I was not sure about it.
Karla
You should review this with the local building inpector. The bulding inspector will want to stop by and witness the test.
It is hard to say but in Costa Rica we dont have local building inspector. But the company that design the building usually do the inspection.
