Does anyone know the ASTM for a Hillside washer?
I am doing an nuclear "NQA-1" project and need to buy some hillside washers to be used with a girt system. The hillside washers are for the sag rods.
I need to know the ASTM a hillside washer is made to so I can get the material qualified for use on the project.
Any help would be great.
RE: Does anyone know the ASTM for a Hillside washer?
I would give Portland Bolt a call as they are normally on top of most specifications.
http://w
I have already looked at the Portland Bolt site as well as the Fastenal site. The Fastenal site listed an ASTM F48. This is a dead standard and was not for hillside washeres. The issue with my need is that since this material is going into a nuclear NAQ-1 site I have to have an industary reconized standard to didicate the material too.
Any thoughts?
If you are looking for the cast washers that retain a diagonal brace rod and bear on the back of the beam or column web, there is no specific ASTM standard for those washers. The shapes are proprietary to the various manufacturers. There would be ASTM standards available for the material that is used to form the washers. ASTM A27, A47, A48, and A148 are all ASTM casting standards that might be deemed to apply depending on the material used in the casting.
I would suggest having your own specification that mandates specific proof and ultimate loads that the casting must meet. Testing protocols could be similar to ASTM F1145 for turnbuckles.
Thanks for the information. It is exactly what I needed. From here I will use the ASTMs you lead me too and develop a didication plan that I can use (with a 3rd party testing firm) to qualify this hillside washers.
