Undermined footing
Undermined footing
I have a project I am working on here in which we have a continuous footing that is undermined by 1 foot perpendicular to the footing. It was done for the plumber to install his piping. I think that this is a relatively small issue, however, can become a big issue in the future. I am needing to know what would be a fast, simple, and cost effective fix for this. I was thinking possibly placing a flowable fill below the footing. I also thought of a helical pier but I do not believe this would be a cost effective solution. Any suggestions?
RE: Undermined footing
However, flowable fill is like duct tape. It tends to fix foundation screw ups whatever they are. I'd say you're on the right path.
www.PeirceEngineering.com
However, for restoring support to what was there before, the post from PEinc does the job nicely. I've even done this for a footing 4 feet wide, ramming in granular fill from the side, horizontally. Use a 2 x 4.
