Import Drawing Format
I'm a Solidworks user and trying help my co-worker with a little problem he's having in Altuim. Question; can you import a dwg or dxf drawing format (exported from Solidworks)into Altium? I would hate if he had to draw it from scratch.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: Import Drawing Format
Yes.  In the most recent versions you can also import/export 3D files to help with mechanical layout.
Dan - Owner
http://www.Hi-TecDesigns.com
Does this hold true for 2D dwg/dxf files. I should've stated it in my post. My bad.
Thank you
Mechanical Designer
