Nozzle check valve
Nozzle check valve
Hello everyone.
for the design of some nozzle check valve I have the following conditions:
- Mass flow rate max
- Mass flow rate min
- Upstream pressure
- Density
It is required that those conditions the valve allowing all the mass flow rate and that the valve disc does not vibrate on the plant.
Does anyone know give me some suggestions on this?
I had thought to calculate the CV but do not know the pressure drop.
Anyway, I could not predict whether the disc will vibrate.
- Upstream pressure
- Density
RE: Nozzle check valve
Nor could I. Generally, it will be a question for you to ask the valve manufacturer (good luck), or for you to go and test.
I am the manufacturer, but it is the first time that I deal with this type of valve :(
