Changing NX Part Material using NX Part Attribute???
Hi all,
My name is Magnus and i am new to this forum.
I have a question regarding assigning/changing material to an NX Part using the NX Part Attribute "Material".
Is this possible?
In detail,
Say that we have a Teamcenter Enginnering (2005SR1) enviroment managing NX (Version 6). In this enviroment the NX Part attribute "Material" is mapped to a Teamcenter attribute "NX_Material". The Teamcenter attribute "NX_Material" has a LOV, a list of values that are relevant for this attribute, i.e. all relevant NX Part Materials.
Can NX be set up so that the users can change the material for a NX Part in Teamcenter, using the Teamcenter attribute, which through the mapping gets updated to the NX Part attribute "Material" which in turn then changes/assigns the part material?
I hope my explanation isn't to confusing.
Thankful for any respons or input.
Is this possible?
In detail,
RE: Changing NX Part Material using NX Part Attribute???
However I'd still be interested to hear why you would want to do this? How often would you design a single geometric definition of a product that would have a material change that you don't reflect by changing the drawing of it? It seems like a dangerous thing to want if you're not careful about how it might be used. Sometimes knowing that a system can't do a thing that you possibly don't want it to be able to do has a reassuring aspect!
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Without knowing NX well enough yet, i think this functionallity would be possible to create by writing a script that changes the material of the part. That script should be executed at NX Part Open after the attribute mapping has been performed. I think this would be a fairly simple script but i dont know how or at what events you can get NX to trigger scripts?
Best Regards
Hudson
www.jamb.com.au
NX 6.0.1.5, TC 2007
