Dimension constraint Max and Min?!?
Hello all,
I'm struggling with an expression within assembly constraints on NX6 (6.0.3.6).
I'm trying to set a max and min on a dimension constraint rather than being a set at a constant. This is so I can set a movement sequence and check for collisions within the machine. I'm sure it's exceptionally simple but I seem not to be able to get the syntax correct...very frustrating!
Thanks in advance for any help.
Cheers,
Ben
RE: Dimension constraint Max and Min?!?
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
