Weldment - Different peirce points at each end of the member
I would like to know how to set up my diagonal member so that each end is located by a different pierce point. This would allow each end to only have one cut and the cuts would be parallel.
Attached is a picture of the solidmodel with what I have, also a drawing in paint of what I want.
I have solidowrks 2009.
Thanks in advance, Chris.
RE: Weldment - Different peirce points at each end of the member
Your weldment profiles can only be parallel with your sketch lines since they are just swept along the lines.  You'll have to adjust your sketch.
Dan
www.eltronresearch.com
Dan's Blog
Thanks CorBlimeyLimey, I should of thought of that!
