Can a Natural Gas Shut Off Valve be Installed outdoors
I am inquiring if a 2" natural gas shut off valve can be installed outdoors exposed to the environment. I want to know if ASME of Ashrae has any regulation on this type of installation. Thank you.
RE: Can a Natural Gas Shut Off Valve be Installed outdoors
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
If look around your gas line control station you will see all their valves outside.
§ 192.365 Service lines: Location of
valves.
(a) Relation to regulator or meter. Each
service-line valve must be installed upstream
of the regulator or, if there is
no regulator, upstream of the meter.
(b) Outside valves. Each service line
must have a shut-off valve in a readily
accessible location that, if feasible, is
outside of the building.
(c) Underground valves. Each underground
service-line valve must be located
in a covered durable curb box or
standpipe that allows ready operation
of the valve and is supported independently
of the service lines.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
rmw
http://engineerhumor.com/
