lightweight deflectometer
any of you guys using a lightweight deflectometer to replace plate bearings? if so are results comparable and is it easy to convince the client of this?
RE: lightweight deflectometer
Convincing the Client may be more problematic, you have to understand what the equipment is telling you, and how this relates to design. If it is going to be used on a project, it needs to be included in the specifcation at the contract stage. Highways Agency in the UK are using it extensively, and it has also proven very useful in testing the highly variable Made Ground on the 2012 Olympics site.
I personally like the test as it measure performance of variable ground where compliance such as degree of compaction and air void content are difficult to measure with a high degree of certainty. Equipment trials are needed, and it is sensitive in operation. you need a good understanding of what it is telling you before you adopt it as a cure all method of test.
